running 540 pto from hydraulics
Charlieh
Im aware that you can get a unit that basically creates a pto shaft output drive from a hydraulic feed input. Similar to Eddies winch set up on the Kubota, has anyone tried a set up like this from tractor hydraulics. I am looking to run very low hp requirement implements on a hydraulic drive to avoid an issue with not having a pto output on a front linkage.
The tractor has a constant pumping circuit that I can run the implement on and leave the other acting spools free to run the link arms
any pointers would be appreciated
