BG 86 blower throttle return spring
Island Lescure
Hi, there are a few different carbs for these, and if you mean the throttle return spring on the primer ball side of the carb you cannot buy it on its own from stihl, you have to buy the whole carb! However Steve aka spudulike on here reworked my old spring when it went and is still going fine -much cheaper than a new carb, also apparently there may be some aftermarket springs that fit, but you would have to ask Steve. Peter
