Temporary posts up against the hedge , string the wire up , knock in the permanent posts and transfer the wire over ?
This is also another sensible way cheers going to give it a bit of thought.
Lifting the wire over is easy you never lift the full 80kg at once. Just start rolling it out ten meters then bring the roll back to create a slack hump. This will give you some play for lifting over.
It will be like lifting a newspaper. But at the end you will of lifted all them Kgs of wire over.
Cheers goaty. Nothing like experience.
