I was wondering whether anyone can help me identify the defect in the enclosed photographs.
It was sent to me by a colleague for a site I have not visited. He reports that there are a number of lime trees with what appear to be borer holes of around 2cm. If anyone could help I'd be grateful.
That's why I am querying the size. I wouldn't like to meet an insect capable of a cm diameter bore or even an exit hole, but I can easily see some clumsy increment boring doing this.
I think ALB are fairly big, but.....
Why would anyone want/need to put an increment borer into such a small stem. ( L6 student doing a research project on transplant shock and reduced growth maybe:biggrin:)
Edit: The second tree is planted too deep too.
2cm across I believe. I haven't seen the trees myself but my first thoughts was that the holes look too large for a borer, and I would have expected to see more holes with shavings at the base. I did wonder whether it could have been a formative pruning wound (even though I can't see any sign of a former branch collar).
Thanks for the advice about the depth of planting. I'd like to give my colleague a clearer suggestion about what's caused the damage though. Apparently it is on a number of trees.
Look at the sunken are below the hole. I agree with Gary re root related. Your colleague can get a clear idea of the cause if the take a trowel and dig away all the dirt off the stem.
No inspection, no diagnosis.
I'm going with William of Occam on this and saying someone has drilled holes in the trees. Reason could be to test starch reserves (I have done this myself with a 15mm auger drill bit, but only on trees that were condemned anyway). The shavings are of course taken away for analysis. A closer look at the holes that shows they are of uniform diameter would be allthat is needed to back up the hypothesis.
