Thanks people . I really appreciate it . Flywheel sensor is a good 5 mm from the flywheel it may of worked loose ? Battery charged and all associated wiring to be replaced tomorrow . Switches all in order and cleaned . Electrickery for sure . Bypassing may be a temp option :thumbup1:
I set ours to a couple of sheets of paper distance from the flywheel. That could well be your problem.
First thing after tomorrows job I will be on it . Much obliged to you Mr Hoddy and all the best to the Hammers this season :biggrin:
No worries mate hopefully you get it sorted easily enough. The hammers are doing alright so far and with there new signings they will be alright. Ready for the new stadium and big push back into one of he big clubs! :thumbup:
Aye you have had some good signings and no doubt will do well . Thanks for the advice ..... new battery and wiring and also pushed the sensor close as I dare to the flywheel has solved the problem . Chipping great once again :thumbup:
Thanks to all who offered advice :thumbup: Keep spitting chips people .
