How many net bags per metre of logs?
Johnpl315
if u put say 10kg in each net then u should get 100 nets per ton so a 25 ton load should get around 2500 net i would say on average but i could be wrong
I'd say a seasoned net would weigh about 10kg, unseasoned closer to 15kg which corresponds to the 35ish nets per loose cube stated previously.
Hi guys, sorry of this has come up before,
How many net bags would you expects to get from one cubic metre of logs?
What would be the going rate for wholesale net bags, ie. 500 nets of oak. Worth much unseasoned?
Thanks
Unseasoned oak is estimated to weigh about 950kg per m3 so just weigh enough nets to get good average and work it out from that.
good point lucan forgot it was unseasoned :blushing:
Yeah I don't think you come across unseasoned nets that often, maybe because of 2 reasons I've heard from others on the forum. a) By the time the logs (esp oak) have seasoned the nets have started to degrade. b) As the logs dry and shrink there becomes a noticeable gap in the nets, think one guy said he had to reopen all the nets and put more logs in them as people were complaining.
