gearbox oilchange - suzuki vitara
superfurryanimal
Squeezy bottle with tube to put new oil back in... Can be an awkward procedure but I've only ever done fwd transaxles and access to diffs and transfers on a 4wd is probably easier. If you need a GL-5 hypoid make sure it is; GL-4 isn't really a hypoid.
Saying that, if the synchro is worn or stiff, it might be worth looking at RL gearoils which are non-corrosive to the synchro. Clash might justify a thicker grade; what's the mileage on the vehicle?
Edited by TimberCutterDartmoor
thanks for the reply, it's done 87,000
