Pattern parts
Pommie
Looking to replace the piston and barrel on my ms200t.
can anyone recommend a pattern part? i have seen Nikasil and Hyway.
Or is it a case of just buying original parts
Use the original cylinder unless the plating has worn through or there is scoring through the plating (do not confuse with seize transfer).
Fit a Meteor piston and all will be very good. The plating very rarely wears through and doesn't wear enough to warrant replacement.
Nikasil is the plating that was developed by Mahle who manufacture many OEM parts and not a manufacturer. Originally Chrome was used many years ago but Nikasil is harder.
