Hello spud, thanks for all the advice👍 I put the new meteor piston and ring in last week. The saw started easily and does seem to run better but I'd say it's still a bit gurgally when I'm not pushing it hard. What could be making it only clean up on the revs when it's under pressure? Maybe a little to rich?
If the saw is run flat out freestanding, if it gurgles, it is probably running rich, Max revs are 14700rpm but usually set to 13500 - 14000. If it has a blue coil, it will be limited to 14100rpm.
If you are talking about the gurgle on mid revs free standing, dont worry about it, they all do it!
If the top end revs have been tuned correctly, the plug will go a md tan colour after 30 mins to 1 hr use.
