Milling Pine Trees
pinetree paddocks
It's not easy to tell you where to section the tree for milling.it depends on alot off things.what it is being used for,trunk diameter going up the trunk.The aim is to cut sections off the tree with the diameter the same at each end or similar.theirfore getting more out off the tree.I find around the nine to ten foot mark I can cope with,lift and move on my own.
