Shavey, dont forget to pm me a price for a ps32:thumbup: with carving bar and chain please.:thumbup:
I will get that one this week Harvey did you want 10" 12" or 14" bar
Most carvers want a 1/4 set up did you want that or just the 3/8 carving set up thanks:thumbup::thumbup:
  • Replies 51
So that's interesting I always thought the 084 only came in 050 it shows how misleading things are
Below in the chain charts from dolmar you can see there are two versions of the 099 3/8 chain semi chisel and full chisel 5.2 mm file and 5.5mm file
Full chisel .325 had a 4.5mm file to sharpen then near the end 4.8mm file
Semi chisel .325 had a 4.8mm file right through the life of the chain
Iam probably barking up the wrong tree :lol::lol::lol:
A (full) chisel .325 .058 that takes 4.5 mm file would be the now discontinued 34LG (unless it is the "green" 34SL) if Oregon, and it certainly would be wrong to go up in file size at the end of the cutters "life" - rather the other way around (as always).....
If it is Stihl, it would be 25TS (Topic Super, also discontinued), but I assume it wasn't/isn't.
Looking closer at that listing, I suspect there are some misprints/mistakes there - I wouldn't trust it....
Edited by SawTroll
