Dolmar PS 420
outonalimb
  • Replies 51
Dolmar 484 is 0.325"pitch and 0.050" gauge so its either equivalent to Oregon 95vpx or 20bpx.However with rakers it must be 95vpx narrow kerf.
T.C.D your bar would be 325 x .058
Indeed. Recently I changed from 050 to 058 and hadn't figured on the increase in chain oil consumption, it was very noticeable. I tend to run the oiler at max regardless so perhaps should knock it back a little. The 050 was an original Dol 16" and I changed to a Dol 15" which happened to be 058, down the rack it ran out of oil before the fuel did...
The 086 , 484 ,686 dolmar chains come in 050 058 and I think they are
20 LPX or 20 BPX .050 gauge
The dolmar 084 is the 95VPX only available in 050 1.3 mm
What you must remember is the following
20 BPX or LPX is 050
21 BPX or LPX is 058
22 BPX or LPX is 063
And for that saw you can get the 95 vpx 1.3 050 64DL
Or you can as CJ says run stihl Rs chain which I have tried on that saw and it works ok
I have bought a spare loop of 95VPX and may well just stick with that. I haven't yet used this saw in anger so time will tell.
Then it is 95vpx/H30. :001_smile:
Of course it would. :001_smile:
You can get Stihl RS in 0. 325 x 0.050 and it will run on narrow kerf bars.:thumbup1:
You will need to check clearance between the chain guide plates on the oil feed and the clutch cover.:thumbdown:
Yes, it works with some saws, not with others. I don't know how it is with the 420/421...
