Hi All
This is coming from a very happy amateur, I've had my MS211 (with a 16" bar) for 4 years now and am very pleased with the machine, albeit a bit under-powered I find when cutting some heavier stuff.
I wonder if someone can assist me with which parts/what needs to be done to give the machine a complete overhaul. I've listed a few things myself below (including some repairs), any assistance would be great:
- Will change the oil hose (small black hose underneath as oil is seeping out from there when sitting on the shelf, seems to be a common fault with this model)
- Is there an oil filter to be replaced here or just cleaned?
- New spark plug
- Fuel filter? Again, just a clean or replace?
- Sprocket? Gone through a total of 3 chains since new (2 wore down and one I broke). There are some grooves on the sprocket.
- Clean the airfilter.
Anything else?
Many thanks!
For a 'big' service before I sell a saw on (assuming no other damage/repairs already done) I do:
Carb rebuild (carb kit is under a tenner).
Fuel hoses (and impulse if that's applicable; depends on saw).
Intake boot (applies more to older Stihls).
Rim/sprocket if need be.
Spark plug.
Carb cleaner the clutch/drum.
You should be cleaning the air filter anyway. Maybe a new air filter if the current one looks tired.
Blast the cr*p out of it with an air hose with the side covers and top covers off (with all in/out orifices blocked, natch).
Could add new piston ring too I guess. Depends how 'big' the 'big' service is going to end up being!
:001_smile:
  • 4 weeks later...
