what model is the mog?
Have you ran it up to see how it sounds?
If its too steep an angle, you will likely hear a noise from just behind the cab that doesnt sound right.
Also adjusting the top link can make a difference.
I shortened arms before and that was a couple of hours work for a fabricator, maybe something to consider, obviously you can make them longer too but that can effect lift more.
Pictures help.
It's a1200 no I didn't want to run it as it is Mog manuel says 20 degrees max sounds like it is going to need altering I will try it on a tractor tomorrow to see what difference there is
