Danarm 55 was the creation of Satan, the cylinder so so badly ported, it lost more fuel back through the inlet than it actually burnt, this in turn soaked the air filter making run so rich it just stopped, the whole machine was held together with self tappers ans old bits of tin, the starter was on the dirty side of the machine so constantly failed, the points ignition failed for a pass time, there was no chain brake, or av system on standard machine, the muffler was a re used bake bean tin, which made you ears bleed if you managed to get it to run long enought, the big end was held together with a wing and a prayer. If you wanted a good saw from that era Husqvarna A65 or A77, or if you can find one a F70 or E70
