Sit on Belt
mikerecike
Anybody (Barrie) know what gear drive belt I need to buy for this? I changed the blade drive belt last yr and number is in pic -don't know if that's any help? I painted over the model number panel. It's MTD Lawn flite 11hp brings. Also do I have to remove deck to change the gear belt? Any tips ?(not bin it) Thanks.
It looks like a 548, in which case there are two belts for the transmission Mike.
The front one would be 754-0280a and the rear 754-0281.
If you are really good you can fit them with the deck on, but you need good control of fingers!
Better to take the deck off if you are not to sure.
