Hi Koba
As promised I had a look at the two bars just now and the oil holes are exactly the same size. The husky saw has a seal around the oil slot whereas the chinese has none.The oil holes are a little further forward on the Chinese so if you have taken up a lot of chain slack could you have run off the end of the oil slot? Something to check anyway.
Hope you perservere and get it sorted.
