Hi guys I need some new bearings for my cutting wheel. Has anyone used another supplier for this as vermeers price is very high. Also do you have the specs as I don't have the time to take mine off to then order some others. Would be good to have it all ready then I can fit over a weekend.
depending how long thyev been on, drop the belts , remove pully, soak in wd40 ,drift the bearing towards the wheel ,but not all the way ,remove the wheel nuts n bolts ,use more wd40 then use the wheel to drift the bearing the other way , BUT do it on a big lump of wood .or youl fk the end of the shaft .
