If you had the rope pop off a portawrap it was defiantly setup wrong or you had a tremendous amount of slack in the system and no wraps ???
you will be surprised at what a system can hold if the forces are managed correctly , for top roping you can get away with a lot but id be careful doing negative rigging on such a small line , change your sling on the isc block then get yourself a 14 mm bull rope and a fixed bollard, after that you can dump some pretty serious pieces on the system.
Yes we must of had to much slack in it, just don't like it much,
I have a 16mm big rope, big pulleys etc
