Hello there Mr.Timberwolf .
I have noticed that the no stress doesnt quite kick in as quickly as my mates 2006,it drops the revs enough for me to think its not going stop then suddenly does ! Its second hand so not to sure of the history etc but its been looked after fairly well as far as i can see and am fairly handy with most machinery but not sure wether this is normal or a sensor worn or is just how it should be on a 2004 machine ?
any ides be great thanks.
Sam
Hi Sam
The most likely cause for the feed rollers not stopping early enough could be drive belt slippage.
Check your belt tension is correct at 4mm deflection @ 4kg/f and tighten if necessary.
If you require further info give Timberwolfs Technical line a call on 01449 765820 :thumbup1:
