What sort of buildings / shelters do people use to house their mills? Can anyone give me an example of a set up that combines security with ease of use?
Cheers
Nick
What is the span between the upright beams of the lean-to? How do you load the mill? Is height and clearance to the lintel an issue?
Cheers
Nick
Do you know what the height of the lintel is as I will probably be using a tractor and front loader so cab height will be an issue.
Cheers
Nick
