If it is kretz, which is likely, it could have some wonderful spalting in it...
The bottom of the other stem we felled has some in the first few feet , if this is felled then I shall be getting it out in larger bits if the weather is kind and the field stays dry ,
Did the spalting consist of many thin black lines? If so another good indicator of kretz decay, and not good for a leaning stem in a playground. Be great for turnery and the like, I suppose longer bits could be ripped in half lengthways for manageability, if it's worth your while...
