Hi, all, new to the forum, just bought the above saw, a bargain off e-bay, only problem is that there doesn't seem to be a switch to turn off the heated handles. I've had a good look and can't see that there has ever been a switch on the saw. many thanks John
From memory the switch is on the r/h side rear of the fuel tank, the wire from the right hand heater pad runs to it, the a wire from the other side of the switch to earth under the earth screw on the ignition switch.
