I've got an older R220t from Negri. Its a single feed roller, that needs to be kept sharp, and the spring tensioner replaced regularly for it to be effective. As its a small diameter machine, its struggles with branch unions , so a lot of prep work is required for efficient chipping. No stress control either, so you have to manually adjust the feed roller speed for bigger pieces.
Much better then a gravity feed machine mind.
