Hi all,
I've been contemplating a bigger saw for a few upcoming jobs, I could do with a second for going through big stems anyway. I've currently got an MS460 (18" occasionally, 25" usually, 30" on the odd occasion), and my next saw is a ms241 (16"), I want to fill that gap with a MS 361 or 362 at some point, but am looking at the other end, I've been offered an old MS 066 in good nick for less the £500, what's peoples opinion of it compared with the newer MS660 or the current MS 661?
PS, I'm a Stihl boy, and will probably stay that way, I've not found a husky I like yet.
  • Replies 26
Hi all,
The 066/MS660 has gone through many transformations - one thing to check is that the saw has the "Poly Flywheel" - that's the plastic one as this would make it a much later 066 with the beefed up crank and retarded ignition for easier starting!
The earlier ones had fully aluminium flywheels and a thinner crank and in some occasions, spun the end of the crank off!
The older 066s were however supposed to have more aggressive port timing!
As a 241 owner, I would personally get a 261 CM instead. It is strong enough to where you don't want for a 362 if you already have a 460, and light enough to do the job a 241 can.
If the 066 is in great shape, that's not a bad price.
What you really want is of course a 550xp, to avoid the extra bulk, weight etc of the MS261. :001_smile:
They are better ported - but I don't know exactly when the change happened. It wasn't nessessarily at the same time as the designation changed.
