Hi guys, i have a 2010 Jensen A530t which has started first time everytime until the other morning. I turned the key onto the preheat, all lights lit up then onto full ignition, no power??? Checked power from battery, inline 30amp fuse, etc etc to no avail! PCB board is clean and dry, micros witches seem to be ok. Any ideas greatly appreciated. Thanks, Martin.
poor earth or high resistance in a feed cable check the battery voltage on cranking if it goes below 10-11 volts it would point to a battery have you tried jump leads right on to the starter ?
When you say "no power" do you me nothing happens or a total loss of power?
I would be looking at you safety interlock switches!
1. Bonnet switch
2. If you have a folding hopper - mounted in the middle underneath
The stress control box will not stop the engine starting !
Cheers guys, when i try to start it nothing happens, no lights, no clicking, completely dead, no power? I will try your recommendations, safety switches, starter motor etc. Again thanks for your advice, i'll let you know how I get on tomorrow.
we had something similar with ours it would crank and not show any lights and 1 of the fuses inside the box had fell out i wonder if its the same box with rubber mounts on the back and 4 3mm allen bolts in from the side we ended up putting cable ties round the fuses to hold them in
