Posted · Hidden
Hidden
I am using Inferno 11mm line at the mo, its a great rope with the vt set-up, my only problem with it is it kills my hands to grip it when ascending, which is why I have stuck to using the NE hi-viz for so long. I only have to do 3 or 4 pull-ups and my hands really start to cramp. Any ideas how I resolve this issue as I like the line?
Posted · Hidden
Hidden
1. buy a rope guide
2. sticky gloves, although i believe you wear them anyway
3. wear a pantin, but again, i beleieve you have one.
4. lose some weight
5. set your v.t away from you by either attaching a sling between your harness and hitch set up, or by setting your v.t away from you with
a midline knot.
Posted · Hidden
Hidden
oh heres another thing, try and move more dynamically, ie, dont just hang there like a dead weight pulling yourself, and ditch the body thrusting too, i try and almost leap as i pull. its actually easier to climb faster, and go for an ascent in 1 hit rather than stopping for rests every 20ft
Posted · Hidden
Hidden
1. buy a rope guide
4. lose some weight
a midline knot.
1. Have
2.have
3 have
4 :eek:
5 Hmmmm how will this affect the way I grip the rope to pull up, O Great One?
Posted · Hidden
Hidden
I gotta go 20feet up a tree???????:eek:
Posted · Hidden
Hidden
because it will be self advancing, you wont need to go hand over hand and tend slack every other pull, so you can move in each sequence 2 handed taking wraps round your hands if needed
Posted · Hidden
Hidden
but that's when he has a fag break
Posted · Hidden
Hidden
Thank you for your wise words, Oh Oracle of All Climbing Knowledge, I shall endeavour to work on the pointers that you have given.:D
