The bottom in feed roller on my 2009 tw190 has slid over to the left and is rubbing against the tin work on the machine. I keep clearing the crap out that gets stuck down 1 side but to no avail. Is there a fix for this problem?
Hello
The feed rollers are designed to move from side to side and as long as the 50 hour greasing regime is followed this will lubricate the contacting surfaces of roller box and roller blade edge.
A 3mm shim is available from you authorised Timberwolf dealer which can be fitted between the spline drive and Hex roller to hold the roller away from the roller box.
Part number for this shim is P*20 and your local dealership will be able to fit for you if required.
