mmm interesting J with crown cuts Ive always thought the larger the trunk, & the flatter the growth rings across the board the better the stability?
Its when the growth rings on the outer edges of a crown cut are more perpendicular to the board that that the cupping increases? that's normally the lesser diameter pieces?
But you've cut & dealt with 100s of times more beach than I. :thumbup:
So where would you say peak stability point on a crown cut is? I know the far outer is no good , nor the inner. {other than quartersawn.}
I figured at 8 to ten inches in from the bark, that might be a fairly stable board. {Although of course all beech is horribly unstable stuff.}
I was assuming the second length was the one full of c.2ft diameter branch stubbs? to me that visiblr top side at least is firewwod.
What I presume is a third length looks more viable if the large branch is cross cut out.
any crown cut board is invariably unstable as it is highly sensitive to radial shrinkage and expansion with the first few boards being the worst affected...
nearer the middle of the tree you will still get cupping down the middle of the board so wider boards 25-30" are usually split in to 12-15" widths and then put in a kiln or stacked for air drying.
the very middle of the tree can be quarter sawn and will obviously yield the most stable stock.
not all beech is horrible and unstable. it's been used for centuries in furniture and kitchenware and i don't think it deserves the bad reputation it has.
i use it for my skittles and as long as its dried correctly it's perfectly good wood. the reason people hate it is that it like to dry very quickly naturally and splits because of this. as long as you control the process you have an excellent material to use.
I understand all that Steve, & agree, just with the exception that Ive seen, the outermost crown boards cup a lot so do the innermost, but it seems to me there is a peak point, on exceptionally large trees where the boards are more stable.
At a guess it would be the first outer board of the inner square if one squared the log like a beam first?
Its boards were the growth rings are almost equally flat across the end grain of the board but but the opposite of quarter sawn.
