Am doing a service on the 200t and found that the fuel filter pipe had perished. i had a look on the web for the part and there seems to be two types, i was just wondering if there was any reason for them being different? any info would be much appreciated.
The early ones had a separate breather vent above the fuel cap on the top of the tank, this has the single pipe type. It has a push in white fibre breather with a red rubber mushroom on the inside of the tank.
The other one has a two pipe fuel pipe with the tank vent being situated in the top of the air box and is fitted on later machines.
Thats great spud thanks, its a US ms200t so i wasn't sure if that was why it was different.
No, all UK machines will have one or the other - you just need to check if your tank vent is built in to the top of the fuel tank under the air box or if the vent is mounted in to the actual airbox at the top next to the carb.
Cheers spud had a look and got it sorted so it should be back to work soon haha
Good luck with it and hope it works OK when done!
Me too haha av got a load of other bits to change on it but I might get the dealer to do the fuel line for me, I started with just replacing the spark plug and now av got a list as long as my arm of bits to get lol
