Is the crane operated from a pump powered from the crank with its own hyd oil tank in front of the rad/ behind the grab bar ? Or is it powered from the tractors hyd outputs , if it is powered but it's own pump it is possible to change it over and power from tractor services but it will be a bit slow ere and stop u using anŷ other hyd outputs at the same time . I fit is powered by its own pump the you may have a faulty solenoid valve .
