Could anybody with a modern-ish pto driven sawbench measure the arbor diameter for me please?
I think they are called arbors, the bit that clamps the blade in place on the end of the shaft.
Would be grateful if you could, thanks. :thumbup1:
The arbor is the shaft size and the big collar that the blade fits onto, is this this the size you need as there is several different sizes, or the diameter of the big washer?
On the end of the shaft there is a nut, then a washer then two big saucer type things that the blade gets clamped between.
It is the outside diameter of those saucer type things that I am after.
Read more
