You have probably discussed this in the past, but for us newbees, what type/sort/make etc do you wear or recommend. All be it i do have a bad hip which seems to set the back off and vice versa.
I used to have a weight lifting belt in the truck for the logs. Never relied on it as such but was just a reminder to keep my back strait when lifting.
Now I use an avant for back support :D
Hi mate that's what weight lifting belt there ok thanks Jon
