Bit of a long shot I know but worth asking. Not worried if its genuine or clone
Im after side crankcase cover and possibly a crank. Seems I either get ripped off buying in the UK or have to pay as much in postage as the parts are worth from the U.S (which is still cheaper than the uk!)
Im not expecting something for nothing so sensible beer tokens and postage can be arranged :thumbup1:
Which side cover you need ? Main or small cover ? 13 np correct.
Have got some bits might have a crank too.
Has your con rod gone ? Crank might be ok with alloy cleaned off.
Chris
Im after the main side cover on the power output side.
Yeah its 13hp.
Its more a case of im using an electric start 390 engine out a generator for a log splitter im building. Unfortunatly its a tapered crankshaft rather than a keyway crankshaft which altho do-able it makes life a bit harder mounting the hydraulic pump as the lovejoys are only available for the keyway cranks.
Likewise the cover on the engine doesn't have the 4 holes in the ring around the crankshaft output as being tapered the generator part actually just uses a bolt thru its centre and bolts into the centre of the crankshaft rather the into the cover if that makes sense.
