THanks for the link!
Im putting together a system using some different software that will hopefully allow for data to be collected electronicly regardless of the operating system and also then produce something that can be sent to the client.
Expereimenting with open software for creating databases, forms and will have a ponder into excel when i get a bit more time on it.
The mapping side of things is rather out of my area of expertise but i think i have found some software that will allow for specific page maps to be created on which the trees marked accordingly but cant get it so detailed as to actually draw the canopy spread and root zones but i am aiming this to be used for initial tree surveys.
When the map for specific area / street is opened it will allow the user to simply click on the tree id number at it will open the relevant survey data.
Have yet to figure out how to automatically update the map from the data sheet (i.e if the work has been completed) It should also mean that job sheets, quotes and any thing else can be accessed via the map page. - Some issues are that the mapping takes a bit of time. Nothing is automatic and as im only usuing a trial versions not every thing i want to achieve can be done. So im looking into what other systems people are using, both software and hard ware and how these work, pro's and pluses. - So far it looks like the mapping software will be around 180 - 200 quid.
It is something i have only recently started looking into and have contacted arbortrack and down loaded a few things i have found for surveying.
