JCB 135-125 brake master cylinder
Homegrown
You could try Past Parts over near Bury St Edmunds., Nigel Wigg used to be the guy to talk to.
Specialist Remanufacturing Facility
JCB used to use mineral based fluid systems, these are pretty expensive as they tend to be exclusive. Also used on Rolls, Bentley and the likes.
A
Thanks for the link, re sleeving may be an option.
Yes it's light hydraulic oil that's used and the seals do get damaged by DOT4 brake fluid. It may well be that a previous owner has damaged the seals this way.
Still not found a seal kit yet, even the spanish manufactureres refer me back to JCB.
