Panthermill - does anybody have experience with this?
biofix
Hello,
I am researching on which mill I want to get (for MS 066)
and I came across the Panthermill
Panther Chainsaw Mills
I like that the logs can stay at ground level, and that the bar is fixed on both sides which is different than the portamil, and it can also be used for larger logs.
does anybody have experience with this? all input much apprechiated
Thanks
i think the main advantages of chainsaw milling is that you move it to the log and you can mill wide. i wouldn't want a chainsaw mill which is a pain to move around/can't mill very wide as it is a slow and fuel inefficient process. personally i'd just get an alaskan if you haven't already. if you have lots of small gauge wood to mill i'd take it to a saw mill.
