Pics for mattplace
Brushcutter
2 Bays of 3m Scotts pine. Was abit of a pain to load could of done with being a bit longer really but it doesn't line up so the 2nd longest will have to do. You really have to keep the weight at the front for it to wok.
Hopefully in the 2nd pic you can see the hole that pin goes in to make the frame longer. Basically you pull a pin out undo some bolts and drive forward and it extends then put the pin in and do the bolts up.
