Husky 240 brush cutter carb
urbandekay
Brush cutter running a little rough but jet screws have plastic covers that lock against each other allowing H jet to rotate only anti clockwise and L jet clockwise. What is the idea behind these and how can I adjust further?
The limiters are basically a way the manufactures stop idiots who don't have a clue adjusting their carbs and seizing their machines.
The limiters can be removed completely or the tabs cut off but make sure you actually know what you are doing - the H screw is the one that does the damage if leaned up too much!
