Hiab help
Mortimer Firewood
Hiab in the middle if your only using for log bags will be nice, the hiab trailers tend to go for around the 5K mark,
I want to build one myself from an ifor & I'll be going to the local lorry/plant exporter to get the hiab,
Most hiabs come on a frame with legs so only need to bolt some plate to trailer chassis and if your going to use transit style pump then just use Anderson connectors from tow motor
Good luck with your build
