long arms blade bolts
karl1991
You mean on the hedgecutter head? What do you mean by sliders? Do you mean the rectangular spacer that the bolts go through? These should stop the blades from pinching when you torque the bolts up.
Loctite might be a cure for this problem. However unless someone has tried to take a bit off the spacers to remove play in worn blades (and gone too far) then I can't see why you'd have a problem to begin with?
