Oil pump on a poll chain saw... Help!
magwick
Take a long 5mm set screw put a plain nut on right up to the bolt head, then 2 penny washers or a thick washer. Screw into oil pump then screw nut down till washers contact casing.then hold bolt and wind nut down which will draw oilpump back out. Alternatively split head down and chap down the drive gear, this will fubar the oil pump but it will get it out. i think it is a 5mm thread on the oil pump butcould be 4mm, senior moment
