FS400 problem
Paul Smith
Hi, I'm having a problem with the 400. It runs fine then just looses revs and power. I've tried leaving the fuel tank loose and looked for leaks in the system. If I turn it off and restart its fine again!
Looking at a spare diagram and the only electrical item appears to be the ignition module, could this be faulty?
I had same problem with mine in the end turned out to be a very small mesh filter in carb missed it first time i had a look but once cleaned worked fine
The mesh strainer sounds very likely, check the fuel line isn't holed and before you write the ignition model off, try regapping it with slightly less gap - sometimes if the gap is slightly too large, they can spark when cold but go when warm.
Worth checking the rest of the carb over as well.
