so i got out my stihl ms 211 today , fuelled it then fired it up to check that everything was working correctly. The saw was running for no longer than a minute when i was checking the chain break , oiling and tick over and was making sure if it was idling correctly then i switched it off and put it on the ground , then i noticed that i little bit of clear smoke was coming off the front of the saw where the exhaust was , the smoke only lasted for about 20 seconds till it stopped and i put the saw back away again.
just checking if this is normal so i know that if there is anything wrong then i can get it sorted before i cut wood again. :001_smile:
Or have you cleaned/polished it when before putting it away?
Could you have accidentally dribbled a little bar oil onto the exhaust while filling; and perhaps not noticed?
