PA1 spraying course
Ninjastrike
Yes PA1 is the basic knowledge of using pesticides safely (theory test) PA6A is your Knapsack ticket (practical test).
Most courses do the 2 together and if I was employing anyone to spray using a knapsack, I would be asking to see both those tickets. No tickets no job.
I think you can add PA6AW spraying at watercourses on some courses at the same time if that is what you also require.
Hope that helps.
