Anyone no were i can get a large mount stihl guide bar to fit sd 123 .Needs to match chains i have 84 dl 063 3/8. Only one i can find is 3003 mount.Bar i have is a solid nose,want to change to sprocket type.Thanks
3003 bar mounts are 12mm, aren't they? I thought for 14MM you would need to go with a 3002 bar mount. And then you are stuck with 404 tips from the factory if you go new. I think the 3002 in 21"(AKA 22") has a factory 3/8 option. It might work with minimal fussing.
I think green is the smaller tip for easier and safer bore cutting. 3003, at least in large mount, is 12mm. 3002 is 14mm. I can not say if the fit is great as I haven't tried it myself.
Your bar mount (D033) is a "D" size tail in the Oregon system, so it sounds like what you need is an adaptor that allows you to use either a 12mm D025 (Stihl 3003) 25" called bar, or a 9mm large Husky mount (D009) 24" called bar. Both are availiable in 84dl .063 - but the D009 one likely will have to be ordered.
The oiler holes usually fit between the different "D" mount bars - not really sure in this case though.
ive been down this road several times the 123 ,133;143 PS-9010 DCS-9010 are defianetly DO33 mounts 14mm studs the DOO9 mount is 9mm studs
you can buy a new do33 mount bar from dolmar but again they dont sell a sprocket nosed bar in that mount only solid nose bars
with the 9010 you can put the smaller bar studs in and then you can use D009 BARS but i have'nt heard it done on the sachs dolmar
you have several options
1. use the windsor /sandvik DM ROLLTOP BAR 24''
2 .get a cannon bar or GB bar in 24''
3. get a stihl large mount bar and alter the oil hole
4. new old stock sachs dolmar bar 24''
5.ebay usa have several sachs dolmar 28'' bars for sale
Oopps - an adaptor would of course work the other way - you would have to grind the slot in the bar wider! :blushing:
yes it would :thumbup::thumbup: when it comes too sachs dolmar , oregon on there bar selector guide have no bars available for large mount saws and they have no listings for D033 MOUNT on a PS-9000- 9010 only D009 :thumbup::thumbup:
As it looks in the IPL, the bar bolts on that saw should be easy to reduce in size to take bars with a smaller slot than 14mm - but how much smaller is impossible to judge by that illustration....
Edited by SawTroll
I have studs from a 309 without the flange.10mm though .Do they do a small adapter to take it up to 12mm? Was going to order a 28inch from us .Already got 3 stihl chains for the 25 inch bar so prefer to get bar to suit chains.Thanks
