Hi all,
I fancy putting another attachment point on my bridge - problem is, I have a weaver harness and so can't just add a ring. Anyone know if one of the triangular shaped mallions will fit OK across the webbing, and which size I would need?
Cheers
Joe
Not sure a maillon will do the job. The original attachment ring is designed to keep the webbing strap flat. Maillon will probably distort & crease the webbing no matter which shape as there won't be anything to keep it in correct alignment.
