Ive got a 338xpt thats will start fine first time then just wont start again once stopped for anything , seemed to be like its flooding itself .had one opinon that said the piston and seals could be worn , what do you guys think ?
Regards
Jamie
I had this problem with my mates 338, check the connections on the wiring and give it a good clean. It sorted it out, no probs now. Hope that helps.
Could be the needle in the carb is staying slightly open and allowing fuel to flood the cylinder.
Was thinking it could maybe it could be something with the tuning , how would i solve the needle staying open ?
