sorry talking poop last post been out to the shed and checked my farmi wp36 uses a prolite 158slbk095 bar so your 30 will use a shorter one mines a 15 inch so the prefix will be different but the slbk bit is important or it wont fit .its a standard husky bar fitment so should be easy to find ,:thumbup::thumbup::thumbup:
How old is your machine? new machines use a harvester type bar.
Old machines can be changed to the harvester type bar with a kit, or you could convert a harvester bar type back to the older orgegon bar with the lift wedge on top.
What is the problem you are having, bar wear?
If you have the oregon type bar the code for the bar is 138slbk095 and you also need the lift wedge that is only available from Farmi.
