Hi I have a kubota g21 hi lift and while moving it around after putting the deck back on it let out a puff of white smoke and cut out and now wont start. Its fluid levels are fine any suggestions ?
Sent from my GT-I9300 using Tapatalk
Sitting on the seat is required if the park brake is off ( these can be good at realising them selves and hence sudden engine stop)
Is the fuel pump working? Pull the fuel pipe off the injector pump, turn the ignition on and see if you have a good flow coming out the pipe ( you may need to have clean jug/jam jar to catch the diesel in !)
Is it a chipper, is it a mower or another broken stump grinder who cares we'll fix it!
